Okay, that's a different animal than what I was thinking you were asking. I'd use stainless anchor nuts mounted in the wing's inner rib and nylon screws with the screws running through brass or aluminum tubing. That would be simple, strong and would prevent crushing of the structure while holding the wing tight against the wing root
