Yes, I would do it with two nylon bolts per wing. My reasoning is it would hold the wing tighter than one in the rear as well as take some of the stress off the tube. It would also give you some redundancy in case one of the screws fails. IF you want, you can also install a dowel pin in each wing to prevent the wing from trying to rotate through the screws
