Originally Posted by
oukenfold
ufff perfect Dccalt thanks men, for the picture i was crosing finger they fit, and the nose wheel do you think i have a problem ? its diameter is 75mm? what i see its that the base of the retractor are bigger maybe i will have to drill them
For the nose-wheel, it will stick out the bottom about 6mm as mine is exactly level with the bottom of the fuse, in fact the knuckle of the oleo strut protrudes about 1-2 mm on mine. I think there's enough clearance inside for your 75mm wheel when retracted though, you'll have to work out where to mount a pull-pull cable for the steering as the stock gear uses a direct drive servo.
The main gear actuators should fit in the pockets, here're some more pictures with a ruler:
