RCU Forums - View Single Post - I'll be busy for a while....
Old 10-27-2018 | 08:39 AM
  #59
Tanque's Avatar
Tanque
Progress is being made on my set of Pz III variants, albeit slowly. Working out track tensioners or rather how I want to make them. I believe I've it worked out although I will likely change
to a thinner profile hex bar for the actual adjustment rod. I've been making return roller tires slowly, a rather boring task but grateful I can do it. My goal of bringing all of these models
to the same point so I can take a break from them is nearly realized. At least now they all more or less look like something instead of that pile of miscellaneous parts in my closet.
I've begun tuning the suspensions, making adjustments, new stiffer torsion bars here and there however the final adjustments need to wait until the models are nearly complete as it depends on the final suspended weight.
Jerry
