Dale,
On my 28X I get altitude telemetry readout on demand. I believe it needs version -0006. With earlier versions you only have sounds for up to three preset altitudes.
Select the icon for Altitude. Press and hold the Altitude button. You can set the three altitude alarms in that window. Use Common Settings to set the Voice Output and assign to a switch.
Hope this helps.
Don
