I agree that Monokote is more difficult to use but IMO is well worth the extra effort. If done correctly will not loosen up. I have found the metallic colors to be easier to use then the opaque colors but have not had any real issues with either. I first started using Monokote in the late 1970's and although it has changed some it still is the only covering that gives the results I require.
