Originally Posted by
FUTABA-RC
Use FASSTest 18. You will get 14 channels on the RX itself (hardwired ports) plus up to the full 18 your TX can do using S.Bus.
12-channel FASSTest is intended for stick banging 3D heli flying. You will not see any benefit using it on an airplane.
Thank you for your prompt answer Bill ............. looking at the pictures of the R7014SB, I only see 12 dedicated servo ports (in normal vertical position). I have downloaded and printed the manual and see the horizontal ports labelled S.Bus DG2, S.Bus 2 and DG1, I presume that 2 of these ports are used to obtain the additional PWM channels to give the 14. Which ports are used ? the manual tells me hardly anything about setting up for 14 PWM channels.
Thank you in advance
Andrew Dunan
