Hi Digitech,
I am about to fix the Stab and Rudder, and was wondering how you approached this on your plane. That is, were the…
-Stabs fixed by a screw in the very small opening (rectangular opening of 0.5cm X 1.0cm on the underside of each panel) and going through the Stab Tube?
-Rudder fixed by:
- gluing the vertical tube to the fuselage, and
- a screw at the base of the rudder and though the vertical tube (I would need to make a hole in the dorsal fin to accommodate this), and
- a screw at the base forward of the dorsal fin (where see clearly that we are to fix a screw to the protruding fiberglass mount on the fuselage)?
Mario
