RCU Forums - View Single Post - pull start broken?
Old 11-03-2003 | 12:55 PM
Rex2342's Avatar
Rex2342
Default RE: pull start broken?
It's just like NA said.(BTW NA WTG on the MOD status)The oneway slips when it gets dirty and it needs to be cleaned.Make sure you use Nitrocleaner and not wd40 or any other kind of lube because it will slip even worse.Just take off the pullstart(be carefull not to let it unwind) and give the oneway a good cleaning.
