Originally Posted by
Appowner
I don't see anything there about it being for recreational flying. In fact, even the URL has Commercial in it and it was linked from a section titled,
<br /><br />Again first off are you a member of the AMA or just a hater.<br /><br />Second have you registered with the FAA????? <br /><br />Third you missed the point entirely so let me explain it slowly for you. The........chart.........as........an..........exa mple..........clearly............shows............ the........FAA.......... can.........issue...........waivers. From..........listening...........to..........what ..........the...........AMA...........have........ ...been...........saying...........I.........get.. ........the...........idea..........this........is .......the .........path........they.......are........taking. .........which..........would..........be......... .similar...........to..........what.........is.... ......happening..........in........Canada.<br />
That would leave you if not an AMA member flying at an AMA field stuck under the original rule without the waiver. Perhaps this is what is driving your hate for the AMA?????
