RCU Forums - View Single Post - While AMA talks, FAA acts...
Old 01-09-2019 | 05:53 PM
  #159
Hydro Junkie's Avatar
Hydro Junkie
Originally Posted by Propworn
Again your not a member why should it concern you????????
If I were you I would be more concerned with how to go about getting that same waiver. Easiest way would be to join the AMA but then you'd have to fly within the safety code. Even members who choose to fly outside the safety code will find they are not covered by the waiver and fall back to the all encompassing regs.
Obviously, you didn't read what I posted. Let me sum it up for you:
1) The AMA spends money to help a club in financial need is a good thing
2) The AMA spending milllions on a facility in Muncie that will rarely if ever be used and has no way of generating an income to pay for itself is a bad thing
Seems to me that this should be a no brainer but, obviously, it apparently isn't. Once again, my being a member or not is meaningless. This comes down to what is the best use of AMA member's dues and what isn't
