RCU Forums - View Single Post - While AMA talks, FAA acts...
Old 01-10-2019 | 06:36 AM
  #170
Appowner
Banned
Originally Posted by Propworn
It looks like the FAA is going to release a set of rules for recreational use with altitude, possibly speed and distance from structure and people. This appears to cover all recreational flying. The FAA is making the rules not the AMA.
The AMA petitions for a waiver to these limits for members only. How does this effect you the non member. The AMA didn’t have anything to do with your predicament.
If you had read the new FAA Re-authorization Act you would see where the FAA has been charged with producing over time a number of things with regard to sUAS. While the new act did officially revoke section 336, the new rules I expect will make that functionally true.
And the AMA with it's efforts to leverage the law to require mandatory CBO membership (with the AMA being the only CBO) seems to have fallen by the way side. So everyone will be flying under the same rules. What a concept!
