RCU Forums - View Single Post - New: Pull-Pull System - Need Help!!!
Old 01-16-2019 | 07:52 AM
j.duncker's Avatar
j.duncker
Your horns on the control surfaces must be the same length as our servo arms. THIS IS ESSENTIAL other wise you get extra loads and probably on the non pull side slack once you move from neutral.Possible source of flutter.
The wires MUST run straight from the servo to the control surface. As others have said your layout with tubes will never work
