good catch tony i didnt see he did bypass that use. heat rises and your in the heat zone by turbine there. if worried put in a sleeve guard like your wing harness is but i assure you it wont melt the tube so your wires will be safe. tie off to bulkhead when it makes the transition at bell mouth to next tube into tail.
