Originally Posted by
marc s
Re wire pliers.
I have built loads of jets for customers in the past and have always found safety pliers to be too bulky for use on our kits, often access is tight and the need for a more agile tool in needed. I made a safety wire tool which I have used for 10 years without fault and its cost me a few cents.
Find a steel solid rod around 4mm in diameter, file or Dremmel one end to a flat, about 20mm in length so it resembles a flat head screwdriver when looking on end - about 1mm thick should be fine. Then drill one hole near the tip (round off the tip edges) about 1.5 - 2mm in diameter (enough to pass two pieces of safety wire through with some spare room) - thats it.
marcs
So this looks like a screwdriver with a hole in the flat part of the tip?
I have several donor screwdrivers in mind.
Sparky
