RCU Forums - View Single Post - Freewing T-45 90mm Turbine conversion
Old 02-11-2019 | 08:43 AM
Tip22v
Here are some pics of my setup using the kit from HAB. The tank fits very nicely right over the CG, I used a hacksaw blade to cut the opening for the tank, worked well and did not make a big mess. The bracket for the exhaust tube fit perfectly into the grove for the EDF fan unit, which is upfront, I assume this is how it is supposed to be mounted? If the included bracket is supposed to be near the rear can someone show me where? Also, if the bracket goes somewhere in the rear how is the front of the exhaust tube supported? If the bracket does go forward, how are folks supporting the rear of the exhaust tube? Thanks for the help. -Tom
