Hi Mike
Check post #47 in this thread for info on the Tail Wheel I used. There was one supplied but I have never liked the stock BJ Craft tailwheel. I really like that super light one from F3AUnlimited
As for Throws etc. Here's info from B.J. that I used in setting mine up initially (it is in Futaba Speak and refers to Futaba horns and settings):
Rudder servo horn: 40mm FUTABA big round horn. if the arm is too long the Rudder will always over shoot !
> (40mm Small horn + AFR 130% EXP 70% is good/ SNAP AFR 50% EXP 0%)
> 171 servo is too fast for rudder (0.19/sec is best) . AFR Speed, SIM Type / IN 3-7% OUT 1-2%
> AIL : Futaba + type horn, end hole. Normal 40% AFR, Set EXP 25% /SNAP 120% EXP 0%
> ELE : Futaba 6 arm type horn, end hole. normal 80% AFR, Set EXP 15% / SNAP Same.
