RCU Forums - View Single Post - Counter rotating or not
Old 03-17-2019 | 01:07 PM
BarracudaHockey's Avatar
BarracudaHockey
Originally Posted by Skyhawk940
I know some of the motors, to reverse the motor, the shaft needs to slide through the motor and come out the other side. Doesn't make sense to me.
What's a good source of electric props?
Skyhawk
The only time I've seen this required is when the X mount needed to be on the front with the motor recessed into the fuselage or firewall as opposed to having the mount on the back of the motor. Not to reverse the rotation, again, there is no reverse rotation on a brushless motor, its merely a factor of how you have to mount it and what prop you're using, if you need to spin it the other way, as you already said, you reverse two wires.
