Originally Posted by
AndyKunz
The channel processing hasn't changed any. The subtrim values would remain unchanged.
What version were you coming from?
Andy
Thanks for your response Andy.
Unfortunately I did not take note of the version number prior to the Firmware update. Is there a version that your not suppose to update from?
Even though you mention that the cannel processing hasn't changed and that the sub trim values would remain unchanged, this is not the case with my system.
I alerted a fellow RC buddy of the issue and it turns out that he too has had the same exact issue. I have not check how it will affect each and every one of my planes as of yet, but I am concerned.
If the Firmware update has indeed changed the sub trim values when you state it should not, then I wonder what else may be affected.
