RCU Forums - View Single Post - Question for Cortex Experts
Old 03-29-2019 | 08:03 AM
F1 Rocket
If the taileron mix was active when you did the Cortex programming sequence it should work. If not, redo the programming. Make sure the taileron mix is active and that you wait for the first double green LED flash, then start the stick movement sequence.
Danny
