These are only for small engines TD .010 to .049 tops. Requires you use a cut piece of fuel tubing as a slip ring over the pressure line to help
bind to the pressure nipple. I use hemostats to expand and slip the ring over the line. There is not better proportionally sized pressure nipple for TD .010 to .03 engines.
