RE: Heavy AT-6: Will it Fly?
Fly-it!!!!...Had the same T-6 with a G-38 in it and weighed just under 18 lbs and it flew wonderfully.....make sure you fly it all the way down to the runway when landing,using power....if the throttle is retarded too early...results will not be what you want......flaps mandatory for landings or its hot and will hop down the runway til it stops........good Luck....Bill.....
