RCU Forums - View Single Post - Hacker Senstrol Q80
Old 04-11-2019 | 12:47 PM
F3ARacoon
Originally Posted by acro3d_F3A
Hello
I did a test by changing the propeller.
I installed a 21X14 mezlick now I no longer have ESC overspeed but the engine consumption is higher (identical to a 21X13 on a Q80 Normal).
Currently I have 5000Mah batteries once the q80 senstrol well set I will try with 4600Mah batteries.
Soon I will reassemble the PT propeller model 21X13W by modifying the maximum engine speed parameter (6000-- 6500 rpm) in order to shift the ESC overspeed passage point.
At the end of the vetical descent I have to accelerate because the brake is really phenomenal.
You have to manage the throttle handle differently, it's impressive.
to be continued
Can you please provide your idle rpm in the RPM mode? Mine is very low I need to increase it but need some kind of base line.
Many thanks in advance,
Nikos
