Yah! the tray is so heavy I want to use it as a sinker
we are going to use the tray from the broken Cat if it is in good conditions or I will make one out of 1/8 plywood.
Thank you for that piece of info David
On the broken Cat we installed two sets of flex plates, if they survive then I will use those to double the flex plates.
The suggestion to go over the airlines and retracts is good, I wasn't going to BUT, after looking at how the fuel lines came out, I decided to redo every system in it, I will service and test the retracts outside the airplane before they are back in, I use the rc car shock oil #25 weight to refresh the O rings in the retracts, the brakes also need service.
Thank you for the suggestion.
I think after she is back in the air I will deserve a ride or two
