Originally Posted by
jason
Hi David, I also had a Jet Tronic product fail at Bruntingthorpe. Mine was a no loss brake valve and this also worked after a reset. Problem is once the radio is switched off and back on again the valve failed to work again. Might be worth checking yours after cycling the radio a couple of times if you haven't already.
Jason
Thanks Jason. Mine sems to be working OK now but will be replaced with new as a precaution. .
Perhaps I should have twigged it was the sequencer as on first gear test after assembly the gear switch appeared to be reversed yet I had not altered any programming since its last outing.The only thing I had not prepped before Brunty was the gear, as it has 100 reliable since its first flight 10 years ago!
So far as brake valves are concerned, having tried almost all, I believe the Ultra Precision is THE most reliable .
David.
