Hello everyone, banging my head on this one, I have a Jeti DS24 and Powerbox Mercury SRS and Electron Gear with RB45 controller for the life of me I can not get the brakes to work:
Jeti, brakes are on channel 9 using spring loaded switch SG, on the mercury I have channel 9 attached to plug in "H" ( direct 9) I tested "H" with a servo and full deflection using switch SG, tested brakes at the RG45 plug end and have brakes when applied power. program RG45 and all seems to go OK ( when I go into programming mode the brakes are on?) but I can't seem to get brakes to turn on using switch SG or any other switch/slider. ( bought a new RG45 controller too)
Also on rudder output for steering, steering works when gear is up and nothing when gear is down, ( backward from what it should be) (
It has to be something to do with Jeti and the powerbox, I have another 2 jets with pro-link electric gear and Jeti receiver no issues
thanks for reading and any insight
Angus
Maybe I'm being a little impatient , I've only been at it for about 8 hrs.
