Originally Posted by
JoeJr1485
What are our thoughts on using the HSD retracts but just changing out the front nose strut with the Electron strut for the larger front wheel? Or is HSD retracts (not struts) not good either for the grass?
Joe, this is what Greg said:
I don’t think the leg will attach to the HSD retract mech...so probably would have to get the entire nose gear assembly...would also probably suggest purchasing the Electron RB45 Controller also as the HSD may burn the Electron gear motor up.
