Originally Posted by
pvogel
kg isn't a measure of torque. Ncm or oz-in are the common torque measurements (you could do kg-cm or g-cm as well). Which servo are you referring to Drac1?
The 1609 hits 70-80% of available torque holding my Allure through a 2-of-4 point entry Split-S. That tells me it's too small for more advanced KE flight.
I assumed it would be interpreted kg-cm which is torque.
The 1609. I would be confident with that on rudder, but it's too heavy.
