Foam cut out to accommodate aluminum.
So here you can see stainless screws backing up the glue.
I traced the aluminum onto the float top, and used a soldering iron to remove what I needed.
I will use expanding gorilla glue around the brackets, and epoxy on the rest of the spine.
