Originally Posted by
Daniel_81
Hi Steve, I'm about to fly mine, what do you mean by the stock incidence?
Do you mean you didn't change what it is after you bolted the wings on?
Daniel
Set the Eternity bottom wing at +5 degrees. The top wing should be between zero and +5 degrees depending upon how the plane performs in knife edge flight. My Eternity required a 1/32" shim above the trailing edge of the bottom wing.to achieve +5 degrees incidence. I'm still working on the top wing. With the trailing edge of the top wing touching the fuselage, my Eternity requires a significant shim under the forward wing hold down screw in order not to have negative incidence in the top wing.
