I haven’t received a response to my previous post, so I thought I would explain the problem in more detail.
I am able to setup and display the JetCat telemetry on my Jeti Tx. Everything works as it should, a total of 12 parameters are available to be displayed on my P180RX. However, during startup the telemetry drops out and stops reading any further data. i.e. the data locks up.
I have since developed a work around solution which is to have the GSU connected during start-up (which I normally do). When the telemetry drops out, I go to the “Limits” menu and scroll through until the Telemetry page is displayed. Here I found the telemetry version number has gone from V8.10 to an empty field. By pressing “Change Value”, the version number is reinstated and the telemetry starts to work again. My experience has been that it only occurs during start-up and once reinstated the telemetry seems to work fine. I’ve also been made aware that another person has the same problem on a Futaba 18MZ.
It would be appreciated if you could let me know if you’re aware of the problem,or if your JetCat telemetry adapter is working properly, as the cause may simply be my setup. e.g. the order in which I’ve connected the JetCat adapter, I/O board and GSU (I’ve tried a few combos).
Thanks for your help.
George
