The refurbish continues, I got most of the tray install done, engine is mounted now.
I swapped the glow plug for a kero plug, I suppose I need a Y fitting to split the fuel line into two, one for the fuel in and one for the kero plug, Is that correct? And I suppose it's best to install the Y fuel fitting in front of the engine, correct? I haven't had the opportunity to use a kero plug till now, so I ask
I also build me a tray that will be held by Velcro so it can be removed at any time, it will support the 40oz smoke tank, this tray will go in between the spars sockets, the 40oz tank will end up right on top of the CG point, there will also be a 20oz smoke tank positioned in between the main fuel tanks for a to total of 60oz of smoke oil that can be carried
