RE: AMA Anti 3D Rule, 3D Support Needed
yeah, the AMA is full of it, have you guys ever looked at all of the rules to fly a turbine. And you can only have a hand selected few of "turbine CD's" sign you off for a turbine waiver that's required to fly a turbine aircraft at an AMA field.
One simply way to get around this new rule is to dig out little areas and fill them with water at the field, the rule doesn't say you can't dip your tail in the water.
Personally I hope the AMA keeps comming up with these silly rules, people will not put forth an effort to make the much needed drastic changes unless enough people get really pissed off.
