Well, things a going back in where they were, the next thing to do is radio check, servo checks ( already found one that is no good ) set up and then some
A lot of small things that needed fixing to get the engine, and pump runing but, they are now, I re-solder the batt Y and it's works fine now, swap the old Jetronics dual valve for a new one with fail safe, moving forward.
Programing will have to wait till a couple of weeks, I'll be in LA and going to Disneyland on my next days off so, no work on the jet for a week a half.
I still have to check the fit of all the parts, I know already the the small tube spar fits tight on the right wing and have done some sanding to get it loose, so far it's working.
CG should be right on the spot, with the new playwood tray the nose is light.
