RCU Forums - View Single Post - King Cat help
Thread: King Cat help
Old 08-22-2019 | 09:14 PM
  #138
CARS II's Avatar
CARS II
My Feedback: (7)
The two problems I had, have been solved, moving forward ( how much forward can I go, MAN! )
The radio now is updated to the last software version, 2.01 and all the 18 chls are now working as they should be, I selected chl 18 on the radio, chl 20 on the receiver to drive the smoke pump, the smoke pump is working normal now that is has the new speed control, I think it is working better than before because I was able to slow it down on the second half of the slider, this way we can adjust the speed for more smoke if needed once we use the it for the fist time, two things you have to do to the speed control is to select the pins that will allow you to use LIPO batts and to pull the positive lead from the plastic connector tha plugs into the receiver.
I don't have any other thing to fix or adjust at the moment, now I have to put it back togather.
