RCU Forums - View Single Post - Evolution 33GX issue
Old 08-27-2019 | 01:09 PM
planenutzz
Not sure how a low battery pack would cause this. It had a fresh charge and the battery monitor I have in the cockpit showed full green.
I have an inline micro filter, that was quite clogged - see photo. the micro filter in the carby itself was very clogged. Quick soak in acetone and a clean with a small brush sorted them.
I'm quite convinced the last batch of 95 octane I used was dirty, I normally use 98 which lasts better and has less particles in solution.
the 95 will go in the lawn mower and I will mix up a new batch using 98 octane.
Will run it on Saturday and see.
