RCU Forums - View Single Post - Alchemy by Bryan Hebert of CK Aero
Old 09-05-2019 | 07:22 AM
  #78
drac1's Avatar
drac1
Originally Posted by marco.m
oke guys what do you think off this servo setup
elevator ditex td0606m 7,4 volt 5,7 kg weight 23 gram - OK
aileron ditex td0806md 7,4 volt 7.0 kg weight 40 gram - OK
(option ditex td1609s 7.4volt 13.2 kg weight 63 gram) - Overkill and too heavy for ailerons
rudder ditex td2211s 7.4 volt 19.0kg weight 65 gram - OK, but a bit lighter would be good. Around 15 kg and the 40 - 50 gram mark is what I look for.
how much torque do you need for the different surface
thanks marco
See bold text above.
Please note: I have not used these servos, so can't comment on the servo quality. I'm referring to torque figures and weight.
Scott
