One benefit in this concept is that if you end up in situation where you want/need to change kV or behaviour of the drive, it is possible to change gearing. Normally you just change smaller tooth wheel and cf plates and the rest is kept as is.
There are more choices available than with current outrunners (+Plettenberg).
BTW, this is very silent. You can only hear the prop.
