Take a popsicle stick, wrap it with a medium to fine grit sandpaper and use that to widen the slot slightly. Just make sure you don't angle the sides of the slot so the stab stays parallel to the wing. It won't take much to make the stab fit the way you want so be gentle with your sanding.
