RCU Forums - View Single Post - how to glue this ?
Old 09-24-2019 | 08:17 PM
the Wasp
Originally Posted by jester_s1
I'm not too sure about that one. A tight wood to wood fit is the most important thing for a strong glue joint. Assuming the parts aren't in a bind, opening it up will just require filling the gap with glue. That doesn't ever make for a good build.
It's ok if some glue pushes out. Press it into the wood so it soaks into the pores on both the fuselage and the tail. Wipe off what smears and press it into the joint after it's in place. Clean the residue with alcohol before it starts to cure.
no binding, it's a good fit, just a little tight, how about using "TiteBond" (3) wood glue, I know a lot of plane builders use it for framing. being thinner it will soak into the wood more than epoxy and have a longer work time than epoxy. but it will also be scraped off easier than epoxy as the Stab is being pushed into the slot
thanks for replying
Jim
