RCU Forums - View Single Post - Next project
Thread: Next project
Old 10-02-2019 | 01:17 AM
CARS II's Avatar
CARS II
My Feedback: (7)
I got all the control surfaces all dialed up, tested the gear, it is good and holds air in the up and down position, tested the brakes, they are working good but it is leaking air from somewhere ( have to investigate )
The radio batts are in the packets, now I got to find a place for the ECU LIPO, I have two options here, I have to make the LIPO removable at any time.
The CG is close, I will end up adding some ballast to move it back some more to get it closer to the 100mm mark.
Tested the turbine's starter, it is engaging fine, the turbine' s bearings sound good, all checks good on the GSU, I will run it tomorrow.
The refurbish is done, I just have to complete a few items to be ready for flight.
