Originally Posted by
Push
Hi Alex,
really great design you did. I'd like to build one, too.
I plan to make the parts on a CNC drilling machine.
Would you be willing to share the original dxf files, so that I can create the input files for the drilling machine?
Cheers,
Ro
Hi Ro,
You can find the drawings in the first post in this thread:
http://www.rcuniverse.com/forum/12531336-post1.html
You can also find the 3D models for reference in post #4.
Anyway, please read carefully this part of the post:
"All the major structural parts are found inside the “Laser Cutting Files” folder - I do not recommend cutting these parts on a CNC router! To ensure proper interlocking between parts, I used a small offset to compensate for the width of the laser beam. This offset is quite small for soft balsa or liteply parts (0.15mm) but it can be double for tough materials like the 3mm hard plywood. If you use a CNC router, you will have to sand off this small offset to make the parts fit."
