I got to fly thw Roo twice today, after the first flight, I noticed fuel on the fuse under the engine again, removed the front cover and this time I was able to pinpoint were the leak was coming from, it came from the propane brass tubing, my fix, I removed the two 3mm festo fittings and added a 4mm fuel line at the brass tubing, flew it again and whala!! no more fuel leak, I'm not sure why they use of two 3mm Festo fittings and a small piece of brass in between.
Anyways, all is really good, had two flights today, AWESOME, AWESOME!!
Moving forward with the next project, most likely the HSD F16.
Last post for this thread.
