1.5 turns out on the low end is a bit much and may indicate the issue. Either you are over priming due to the rich setting or you have a fuel delivery problem.
Other thigs to consider is low compression due to the rings not being seated yet, your plugs. It is suggested to run genuine NGK CM6 plugs gapped at 0.26 or a weak spark.
