Over current usually means the ECU is seeing more than a 30A load. I presume you have not extended any of the cables? Do you have a spare ECU to Turbine cable, the black, red, yellow one.
Also if you do a burner test in the test functions and look up the tail pipe, can you see a glowing rod in the combustion chamber?
