In between 4 sets of JP, I had one brake that suddenly lockup after about 40 flights or so....tire required....2 actuators motors and the last one...also cost me a biela 24x12 turbo prop and $500 of motor to fix the K45TP, 2 trunnions that the bearing fall of once I took it out...on both side got 2 trunnions to replaced them, but it seem that one of those motor is on the way out....with that and the TP I told myself enough of this and order 3 set of Electron’s
The only JP left is in the mini T-1, but I might change them as well before something happen the brakes are terrible like the other ones.....I haven’t decided yet will do a good inspection this winter....
I know some really like them good for them, I’m done with thing that breaks sometimes (once is once too many)!
