RCU Forums - View Single Post - Aileron AS Flaps together How?
Old 11-28-2019 | 05:36 AM
suzonka's Avatar
suzonka
My Feedback: (7)
Default Aileron AS Flaps together How?
I recently saw a newly sold RC electric cub type plane - no separate flaps, it stated in the specifications the aileron's can be set to also to be used as flaps. I figure if that is just a radio setting and you do set it so the flap switch turns on { do you lose the ailerons in that switch mode when coming in for a nice landing, or does it turn your aileron's in to just up and down straight across movement like real flaps work , I would think you would still need some aileron function to keep the plane steady on landings even if the ailerons Both sides went down a little in the flap switched mode whats going on with this set up -can any one explain it to me. I believe it was a HZ sport cub
