Originally Posted by
Don Szczur
Jim,
Come into Figure Z slow with tight radius just past center, making the maneuver not too tall at the top as a result. Start the comet later, make the down line shorter and resulting 3/4 loop high and tight which brings it down with enough room to do straight and level before the 4 point.
See you,
Don
Are you sure performing the loop high gives you more room for the 4 point roll?
Comet Loop Low vs High. Much more distance from exit to centre when performing the loop low.
