Mark,
When you say; use a normally ON switch. Do I understand you correctly that you put a switch inbetween the telemetry unit and the Rx (or between the ECU and the telemetry unit - that is normally on) and to switch the signal/power? Then, when switching one of these ways, does that reset/start/switch off the telemetry?
JanR
