RCU Forums - View Single Post - DLE-111 Ver 2 won't fire
Old 12-26-2019 | 06:25 PM
planenutzz
Default DLE-111 Ver 2 won't fire
As the title states my DLE-111 won't fire. I had it running yesterday trying to tune the low needle and was doing a full throttle run, then back to idle. Engine quit and have not been able to start it since or even get a pop.
I have fuel through the carb, plugs were in fact wet when I pulled them out, they are NGK. I then put plugs back into the boots and rotated past the hall sensor, I get spark to both plugs but would not say it is super strong. Battery was freshly charged.
I then tried with one plug in the engine and one out with the plug in the boot and rotated past the sensor, plug out had spark but looks to me to be weak. Interestingly I got a slight kick from the other cylinder.
Can I assume hall pick up sensor is ok?
Can I assume the battery is ok? Reads 7.4v LiION pack.
Ignition module stuffed?
